Sure Cuts A Lot 6
- New effects added, including Cast Shadow, Monogram, Rays, Rhinestone Scatter
- More options to customize Rhinestone designs
- Create Data Source Copies to easily replace text for different variations of the same design
- Set cut lines to be scored
- More options to choose, select and replace colors
- More path options to Divide overlapping shapes
- Convert square corners to rounded corners
- Text can be imported from SVG and PDF files
- Larger workspace area
- Generate bar codes (PRO Version only)
- Options to control the cut order (PRO Version only)
- Apple Silicon (M1,M2) Native Mac versions
- and more!
Upgrade from a previous standard version (1-5) to version 6 for only $34.99 *
https://www.craftedge.com/purchase/craf ... _scal6.php
Upgrade from previous PRO version (1-5) to version 6 PRO for only $74.99 *
or from standard version to version 6 PRO for $139 *
https://www.craftedge.com/purchase/craf ... al6pro.php
* Sales prices are good until March 31, 2024
Sure Cuts A Lot 6 is now available!
Re: Sure Cuts A Lot 6 is now available!
I really want this feature:
Support the multiple pages with nesting, so when nesting it can automatically place the objects on the additonal pages, and sort by colors.
And in the Cutting task it can cut the page by page.
If so SCAL would be a big winner.
what version of MacOS does this support?
and what version of MacOS does v5 support?
thanks!
thanks!
Both are compatible, so far, with Sonoma if that's what you are asking. Of course, Sonoma is still so new and being updated that it's possible new bugs may surface. I know of another brand of cutting software that is having a LOT of issues with Sonoma. But so far, none of those same kinds of issues (display changes), frequent crashing, or inability to import certain files have surfaced with either SCAL5 or SCAL6.
- Contact:
Crafting a provocative question.
I need to respond with an unusual and provocative question relevant to the crafting forum about the Silhouette Cameo and Sure Cuts A Lot (SCAL). The format should involve a topic line followed by a more detailed question in a few sentences. I think I could explore questions about the legal and ethical implications of using cutting software, the reliability of third-party software, or the ethics of importing fonts, as these seem to be provocative areas.Proposing a provocative question
