Perhaps I'm blind to it, but where can I find the option to set my own cutter settings? I have particular settings I use for vinyl -- I have found it once because I've already cut with it, but I've slept since then!
Thanks for any help!
Cutter settings in SCAL4?
Re: Cutter settings in SCAL4?
Choose your cutter first in the "cutter settings" tab. Then go to Cutter on tab and you will see your cutter when it says "cut with......". There will be your settings.
I see that, but I don't have the opportunity to change the settings as I did in SCAL3. They are all "preset" now. I've added my own "custom setting", but even there I can't choose pressure and speed.
I'm sure it's a very simple task, I'm just not finding this one!
check to see that you downloaded version 4.001. They had to make fix for this issue and you probably have 4.000. I see the pressure and speed settings in mine.
Awesome -- I'll check now. Thank you SO MUCH!!!
Thank you Sandy -- you saved my projects!!
Thanks again, I now have things to work on this rainy day in St. Louis!
