Cutting with Cricut Expression
New to using SCL 2. I've got everything ok until it comes to cutting. When I load the mat into my Cricut Expression and want to cut mutiple cuts of the same letter, the mat moves halfway down and cuts in the same spot instead of cutting a new letter each time. HELP!!! Thanks!
Re: Cutting with Cricut Expression
Hi, I'm not sure I understand. Do you have one letter on the screen and are trying to cut out several of them all at once? If so that is your problem. To cut the same thing multiple times you need multiple letters on the mat. You need as many iterations of the letter as you want cut.
The multi-cut feature if for cutting through heavy material where you need to cut several times to get through the material, like chipboard.
If I've not answered your question correctly then try explaining again. I'm a bit slow on the uptake sometimes.
inoder to cut multiple of the same image place the image multiple times on the mat
if you only put one image on the mat and select multiple cut it will cut how ever many times you selected in the cut window not cut that many on the page
