sure cuts
Posted: Thu Feb 06, 2014 7:15 pm
by summer flowers
How do you separate objects in a group?
Re: sure cuts
Posted: Fri Feb 07, 2014 4:21 am
by sstehman
Select your object. Go to object on menu bar. Choose ungroup. If you look at your layers panel, you should see the individual ungrouped pieces.
Re: sure cuts
Posted: Fri Feb 07, 2014 8:55 am
by summer flowers
I did what you said, The ungroup is not high lighted what's wrong ?
Re: sure cuts
Posted: Fri Feb 07, 2014 9:38 am
by talanhart
Did you select the artwork. Ungroup won't work if nothing is selected.
Re: sure cuts
Posted: Fri Feb 07, 2014 11:04 am
by summer flowers
It seems like the ungroup does not highlight.
Is their a update I should do.? Every thing else seems to work.
Re: sure cuts
Posted: Fri Feb 07, 2014 3:00 pm
You might try object/break apart on the selected object.
Re: sure cuts
Posted: Fri Feb 07, 2014 3:29 pm
by sstehman
Is it an .svg you are trying to ungroup or did you put another file type on your mat, such as a .jpg.
