Old version SCAL causing phantom cuts?
Posted: Thu Dec 05, 2013 10:37 am
by go2guy
I purchased SCAL version 1.016 a few years ago but I have just today installed it for use with my Cricut Expression machine (also bought years ago and just now being put to use).
The SCAL program loaded correctly and I activated it using the code on my CD package. Under Help > About it shows my name and serial number which I assume means activation is complete.
When I try to cut a project, however, a couple of lines are cut across the text from one end to the other.
I understand this occurs with the unactivated trial version, but I assume that's not the case with mine . . . or is it?
I see now that support for this product terminated at the end of 2011. Could that mean my activation is in fact invalid? Could this be causing the cuts across my work? Or perhaps it's some other issue such as cutter blade postion or pressure setting?
Any help will sure be appreciated.
Re: Old version SCAL causing phantom cuts?
Posted: Fri Dec 06, 2013 4:43 pm
You will need to contact support at craftedge. There is a form on craftedge.com under support.
Good luck.
