Spiral Help
Posted: Fri Feb 06, 2009 4:04 pm
by curlyquills
I'm a newbie to SCAL and InkScape, and need some help with a spiral. I have made one, and adjusted the line to have more of a flower look, but when I cut it out with scal, it adds a line from the center of the spiral to the end of it. Any ideas how to get rid of this
Jamie
www.curlyquills.com
Re: Spiral Help
Posted: Fri Feb 06, 2009 4:30 pm
Try copying and pasting in place. Select both spirals, Path/combine. Then connect the endpoints of the stacked spirals using the third node tool button from the left. See Susan Bluerobots tut here.
http://susanbluerobot.blogspot.com/2008 ... et-to.html
Re: Spiral Help
Posted: Fri Feb 06, 2009 4:51 pm
by curlyquills
Ok, tried that, it didn't work....
Re: Spiral Help
Posted: Fri Feb 06, 2009 4:56 pm
Post the file and someone will take a look at it. By didn't work, did you mean it wouldn't cut at all, or that it still cut the extra line?
Re: Spiral Help
Posted: Fri Feb 06, 2009 5:03 pm
by curlyquills
Actually, i think it may have worked, I may have accidentally pasted 3 copies on top of my original, so it wouldn't connect the nodes because there were too many. I'm still messing around with it
Re: Spiral Help
Posted: Sat Feb 07, 2009 5:29 am
by curlyquills
ARRGG! Ok, I did get it to work based on those directions, but the only way i could get it to work was if i moved the duplicated image slightly, and then when i go to cut it out, the cricut takes it as 2 separate lines, and goes over the image twice, making the flower pop up as it is being cut....
If i do it the same way the directions are, (without moving the duplicate copy) then when i import it in SCAL, it shows up like if you put one item in, and selected it to weld (when you go to preview, it turns grey).
I have attached my image with no formatting, if anyone can help me with this, i would greatly appreciate it!
Re: Spiral Help
Posted: Sat Feb 07, 2009 6:45 am
Ok, I copied, pasted, and joined the spiral, and when I imported it into SCAL it did show gray in preview, but it cut anyway. When I hit preview again after cutting it showed red.
My guess is that it might be some kind of memory issue? The drawback is that it does cut over it twice. I haven't been able to think of anything that would work without adding the extra line.
