Forever and Always SCUT file
Posted: Fri Feb 05, 2010 12:05 pm
by agcsmom
I was playing with some of the new features and put this together. Thought I would share as I have gotten several great files from here. The font I used is Aquarelle - if I understand what others have said - you need to have that on your computer for this to cut correctly for you.
Thanks to SVG Cuts for the tutorials on the new features.
Re: Forever and Always SCUT file
Posted: Fri Feb 05, 2010 12:09 pm
by talanhart
That is a great file. If you have 2.010, you should be able to convert the font to outlines and that way we won't need the font to use the file.
Posted: Fri Feb 05, 2010 12:12 pm
by agcsmom
AH! Thank you for telling me that - now I understand WHY I would use that feature!!!!!! As always - THANK YOU for all your help! As soon as I get back home (quick errand I will do that and re-post).
Posted: Fri Feb 05, 2010 12:31 pm
by missiethegal
talanhart wrote:That is a great file. If you have 2.010, you should be able to convert the font to outlines and that way we won't need the font to use the file.
ooh good thinkin'!! Already applying the newest features in your brain ;)
Posted: Fri Feb 05, 2010 12:54 pm
by agcsmom
I can't seem to do it now. I must have needed to do it before I did all the joining and unioning etc.... Next time I will do it!
Posted: Fri Feb 05, 2010 2:24 pm
If you used Union instead of weld, it does it automatically. You can double check this by clicking on the letters with the node tool. If the nodes appear, it has been converted and is now a Path rather than a font. When you convert the text to outlines it seems like it needs to be ungrouped before you can use the node tool though.
