This folder is a Spellbinders Wizard die cut folder called Daisy Patch. First you run it thru your die cut machine (mine is a Cuddlebug) using this formula: Plate "A", Plate "C", Die (ridges facing up), Plate "B".pastda3 wrote:Another question. Where did you get that embossing folder I really like it.
Then I ran it thru again to emboss using Plate "A", Plate "B" Die (facing up again), Cardstock, Tan Wizard pad (I also added a thin piece of cardboard), Plate "B".
I used the "Dotted Swiss" Cuttlebug folder for the insert. I think I just used chalks for the minimal coloring.
The tricky part is lining it up to use as the front page of a card. You could also just cut it out and glue on a card.
If you search for Cuttlebug stack recipes you should be able to find a great recipe resource to use all kinds of dies/embossing folders in your die cut machines. I found mine under Cuttlebug Sandwich Stack Rules.
Where did you see the tutorial on cutting out on embossing designs?
