Someone earlier shared their file of swashes with me but I can't remember who. I created a bunch of designs but did not cut them, and now see that they won't load and it seems to be something with the swash. I've worked with them in Inkscape and it they appear to work just like every other design. But when I try to load them in SCAL, I get "cannot load svg" as the error.
The file I'm enclosing shows what I'm trying to use the swashes for and also has the swash itself seperate. Thanks in advance.
(Windows XP, SCAL2.012, Inkscape 0.47)
Swash help
Swash help
- davis swash.svg
- (843.99 KiB) Downloaded 122 times
Windows XP, SCAL 2.102, Inkscape 0.47
Re: Swash help
All you need to do is select your artwork and copy/paste it into a new document. For some reason if some of the Live path effect editor features are used, extra code is put into the file that SCAL doesn't like. Copy/Paste to a new file has always worked for me. HTH
