Expression is cutting as if it only has 6x12 mat
paintitforme
Post by paintitforme »
I just purchased an Expressiona and it has 2.31 firmware -- I wasnt sure if I needed to upgrade or not but I did anyway and it is still showing 2.31. With that said, when I tried to cut a shape on the 12x24 mat it cut half the shape ( what would fit on the 6x12 mat for my other circut that I was using prior to the expression). The 12 x 12 mat size is selected when I pressed cut -- what am I doing wrong?????
Re: Expression is cutting as if it only has 6x12 mat
This sounds like what SCAL2 did when it was first released. Make sure that you have the most recent version. http://www.craftedge.com/download/download.html
Also, make sure that you are selecting the right machine when you cut.
paintitforme
Thanks, Heather --- I think maybe I did select the wrong machine -- I tried again and made sure I selected the expression and it worked. Thanks for your help -- All this crafting can get quite technical!!!
