Double. Cut possible???
Have scal2,3 &4. Can anyone here tell me if I can use, I.E., say a collegiate letter, shadow and then Have it I guess cut twice. I want to know if I can cut between font and shadow, weed out and result with letter and a small separate line indentical to the letter. When vinyl is ironed on you have fabric show in between the two. ????
Re: Double. Cut possible???
I think I know what you're saying and yes you can. You won't even have to double cut. Just make sure they are positioned the way you want them to be. Click on the view tab to see where the cutting lines will be. If you're not 100% certain, do a test cut on some paper first. I hope I understood you correctly and am not giving you a wrong answer. haha That's why I'm suggesting that you do a test cut first.
Pastda3, you were 100% spot on. Thank you so very much. I have spent two days fooling with the sf collegiate solid, adding a shadow and going nuts. Selected the collegiate, cut just like you said. Will wonders never cease. Thanks for sharing your knowledge. CF
