Oooo.. I spotted a slight error..
I will adjust and upload again, sorry about that..
Wedding Invite - need some help!
Re: Wedding Invite - need some help!
here they are, just SVG's, I figure its easy enough to import them
The little corner cutouts were 90 degrees on the original which would have likely stuck out a bit after folding, I just made them a bit greater than 90 degrees so it will sit better when folded.
Enjoy
Enjoy
Wow! Thank you SOOO much! it looks fabulous. I am so impressed with your talent and your willingness to share it!
You are very welcomermcleish wrote:Wow! Thank you SOOO much! it looks fabulous. I am so impressed with your talent and your willingness to share it!
If you use it don't forget to share a picture or two
QUESTION on the envelopes with flaps - in preview it appears it is going to cut 2 rectangles basically - I tried to weld them together and preview again and it looks the same - how can I get this to not cut out the inside lines and just the outline of the envelope - I assume you score the inside lines to fold --- am I having a brain freeze or what ?? Thanks for any help
Regards,
Cathy
Regards,
Cathy
wvcathy wrote:QUESTION on the envelopes with flaps - in preview it appears it is going to cut 2 rectangles basically - I tried to weld them together and preview again and it looks the same - how can I get this to not cut out the inside lines and just the outline of the envelope - I assume you score the inside lines to fold --- am I having a brain freeze or what ?? Thanks for any help
Regards,
Cathy
I just go to OBJECT and the UNGROUP and then would delete the inside rectangle, then cut.
need some help! more info
I think I have the envelope problem fixed BUT now is there a way to put 2 small holes on each of the Larger flaps - so they will line up so you could run some twine or something thru it - hope this makes sense - but I would like to put 2 eyelets in each flap and run twine thru it - for a rustic type wedding invite
I have tried several times to line these up just not having luck and I am hoping some of you great people out there know of a simple way to do this
Cathy
Cathy
I am looking to make invitation card for my wedding party venue nyc. Please give me the best ideas for design and quotation of cards.
