I've had a bit of time now to use the updated ECAL with my original Eclips, and like some of the features. Mostly it works just fine.
Prior to the update, I had become a print2cut fanatic. I had it down and it was cutting perfectly. Since installing the new update on the software, my p2c cuts are no longer so perfect. I have calibrated...a couple of times to be sure. But, it cuts down and to the right of my print. I'm working on getting it closer, and am nudging the cut file to the left and up from the print file. I've almost got it ok, but really wish that I didn't have to play around with it like that.
I heard that the p2c worked much better with the new Eclips2, but it was working perfect for me on my original one.
My only other wish list item is that the text tool have the ability to 'return' to type multiple lines without having to start a new text line.
If anyone has any suggestions, I'm open to them! Thanks.
ecal p2c with update using Eclips (not Eclips2)
Re: ecal p2c with update using Eclips (not Eclips2)
I had the same problem with P2C with the new version. I posted a bunch of things that aren't right with eCAL 1.501 here. viewtopic.php?f=7&t=40352
and photos of my P2C test here. viewtopic.php?t=40299&p=130029#p130029
I hope that the P2C is fixed soon since that is now my main use for my eClips. I'm not overly crazy about the new version. It seems like it takes more clicks to do anything since so many things have been lumped together.
I've been keeping most copies of all of the versions since they came out. Wonder if I should re-install the last version until things are worked out.
Just a little bit agitated... The reason for my eClips was for the PRINT-2-CUT FEATURE. Worst thing is I never saved my old install files....
So can someone spare old version install files while CRAFT EDGE decides to fix these bugs....
So I am asking 2 THINGS (to our fellow forum members)
1. Is your ECLIPS and PRINT-2-CUT tabs gone from the EDIT->PREFRENCES menu
2. Can anyone host/share/email a copy of the old version of eCAL software!!!
Thanks to all...
~OnlyOzzie~
Settings were moved to the Cutter Settings window, which is accessible under the Cutter menu or the Settings button when you click to cut your design.
If you need a previous version of the software, you can email support@craftedge.com
If p2c is off (even after calibrating) can you post the values you have for the following:
Cutter (menu) -> Laser Calibration Setup -> Edit Values (button). Need the X and Y values.
Cutter (menu) -> Cutter Settings...: Values X/Y Resolution; Blade Offset; Mark offset,size,thickness; Blade Origin Offset
- Craft Edge
http://www.craftedge.com
I updated to 1.502 today and tried P2C again (Mavericks). Still cutting up and to the left. Settings after calibrating are:
X: 1.008
Y: 0.185
X res: 1.000
Y res: 1.000
Blade offset: 0.70
Mark offset: 0.10
Mark size: 1.00
Mark thickness: 0.25
Blade origin offset:
X: 0.00
Y: 0.00
All of my previous reported problems are still present, plus png images with transparent backgrounds are importing with a gray fill that can't be removed. The gray fill does print.
X: 1.008
Y: 0.185
X res: 1.000
Y res: 1.000
Blade offset: 0.70
Mark offset: 0.10
Mark size: 1.00
X: 0.00
Y: 0.00
I am having the same problem since updating to the two newest versions. Print to cut used to work almost flawlessly with the old version, now the program will not let me calibrate, and all cuts are off to the bottom and right. Any help on this would be greatly appreciated!
See above post from craftedge! You can request an earlier vs of eCal directly and wait until 1 5x gets fixed. Just ask for the last vs that worked for you!hmd wrote:I am having the same problem since updating to the two newest versions. Print to cut used to work almost flawlessly with the old version, now the program will not let me calibrate, and all cuts are off to the bottom and right. Any help on this would be greatly appreciated!
