best cardstock for letters/fonts?
Posted: Mon Aug 24, 2009 2:33 pm
by arimaciasnyc
i use my cricut/scal for letters and the occasional shape.
what are the best cardstocks to use?
i tried a bazzill textured and i almost threw the machine on the floor:)
any ideas would be useful!
Re: best cardstock for letters/fonts?
Posted: Mon Aug 24, 2009 4:43 pm
by jingles0368
i had trouble with that brand too..i use the generic paper...its a bit thinner
Posted: Mon Aug 24, 2009 4:47 pm
The 60 degree Roland blades you can buy on Ebay work a little better on textured papers - less tearing and cleaner cuts. I have switched to them for everything. I also find that the papers/cardstock with finer fibers cut better than ones with more obvious fibers. HTH
Posted: Mon Aug 24, 2009 6:21 pm
by lindamac
The cheaper black cardstock from Walmart and Michaels doesn't cut very well. But the more expensive black papers cut fine for me. I use a 60 degree blade for all uses and am very happy with that. Much better cuts.
Posted: Mon Aug 24, 2009 6:57 pm
by Craigg64
I set my blade depth to 6, pressure to Max or slightly lower and speed to Min to get a reasonable cut with Bassil.
I am using the standard blade but will have to give the 60 degree blades a go.
Hope that helps
Posted: Tue Aug 25, 2009 4:31 am
by tnoehl
what is the name of the 60 degree blade.
Posted: Tue Aug 25, 2009 4:33 am
by Sweetness4713
It's just called a Roland Blade.. Google it and you'll be able to view them...
