stamp
Shelley
stamp
Post by Shelley »
I have not cut this yet... and I will surely scale it down... but I'm going to try to cut it onto a rubber stamp...
library stamp.JPG (96.22 KiB) Viewed 4047 times
from The Wizard of Oz
Tingha Treasures
Re: stamp
Post by Tingha Treasures »
Ive cut quite a few stamps the text is too narrow I think the stamp without the text would be okay. It wont be one stamp it will cut a couple of elements and you can assemble it on a block.
Good luck though
Shelley
Re: stamp
Post by Shelley »
Yeah, you are right... the text is too narrow. I tried it first on paper... I'm working on fatter text now.
Tingha Treasures
Re: stamp
okay I do find fatter text works best :-)
Shelley
Re: stamp
Post by Shelley »
What are some tips for cutting stamps? I know now about fatter text.
What other suggestions do you have?
I have not cut one yet...
Tingha Treasures
Re: stamp
new or very sticky mat is a must. After youve cut your shape Ive often used a sharp small blade hobby knife to carve out some smaller areas to give the stamp more depth!
Shelley
Re: stamp
Post by Shelley »
Awesome!
Thanks for the tip! :D
Shelley
Re: stamp
Post by Shelley »
and I was thinking about what you said about having to assemble all the pieces on the block....
maybe I should connect/weld everything with a bar, and let it cut that way... when get it on the block I could cut all the bars off with a knife?
what do yo think about that?
Tingha Treasures
Re: stamp
well I found I could use elements with other stamps Id cut. If you have a nice circle with centre cut out you can then place another shape or letter(s) in that and swap them about, got that idea from some stamps Id purchased.
