Can you set the shadow layer to a default?
ling
Post by ling »
Just wondering if there is a way to set the shadow layer to a default setting when you open it up? It would just help save a few extra steps when working on a large project. Thanks
Re: Can you set the shadow layer to a default?
Yes, there is. Go to Edit>Preferences (or Sure Cuts A Lot>Preferences on a Mac) and click on the Edit tab. You'll see the setting for Default Shadow Size there.
ling
Post by ling »
Awesome thank you, I meant to add to this post. Do you know if there is a keyboard shortcut to align images to center (middle vertically and horizontally)
Thanks again
There are no shortcuts for those alignments. Just do what I do... learn to use the icons on the Position & Size Panels. :)
