REGISTRATION MARKS FOR LAYERING
Posted: Wed Feb 22, 2017 6:54 am
by tujay0302
newbie here...just wondering if anyone can help me walk through registration marks in scal2 so i can do multiple color layers.
thanks
Re: REGISTRATION MARKS FOR LAYERING
Posted: Thu Feb 23, 2017 11:07 am
Hi, I have looked for a tut on registration marks to no avail, but I have an alternative for u,
If you put all the red pieces on one layer, add a layer and put the blue there etc then you can open each layer, place them on the mat to fit the paper and cut....no reg marks needed.
Maybe these videos will help with using layers to cut different colors.
https://www.youtube.com/watch?v=H8pkru4qVZg
https://www.youtube.com/watch?v=dOGH46FsyOY
Let me know if this helps or maybe someone will find a tut on using reg marks.
Posted: Fri Feb 24, 2017 8:12 am
by tujay0302
Thank you for your response. Those videos are great. I guess what happened is I had watched some people who did the layering with the reg marks and it looks so easy and foolproof.
I think my concern is that I won't get them to line up right doing it manually. I am going to give it a try tonight and see what happens and I'll let you know.
Posted: Fri Feb 24, 2017 9:54 am
Reg marks do not always get the cut correctly. I find that using individual layers if all you are doing is cutting an image, it is easy to line up on a virtual mat and only need the size of paper that you need. I usually place my image in the upper left hand corner of the virtual mat so I know where to put my paper.
Hope we are getting closer to a solution.
Posted: Fri Feb 24, 2017 6:25 pm
by tujay0302
Ok...so I hope this works...this is a file of a phrase in shape of an apple....so if I separate into the two layers say the stem area and the rest of the apple into two layers...you are saying to cut layer one...put the green in top corner of the mat...then switch to red and recut in same spot on the mat just only layer 2?
Gosh I hope that made sense lol. I am sooooo new and really want to figure out what my head is trying to do lol.
Posted: Fri Feb 24, 2017 6:37 pm
by tujay0302
That wasn't a great example as its only two layers and would be easy to line up. Maybe something like an animal or a character with multiple cuts, colors and layers.
Posted: Sat Feb 25, 2017 11:53 am
Before we go any further, let me be sure I know where you want to go with the design,
In you mind's eye how do you see using this image: i.e. as a one piece 2 color element on a white background shape or cutting out the red as a stencilish out of red paper,????
I'm obviously confused so back to you before I lead you astray
Posted: Sat Mar 04, 2017 11:43 am
by Deickson05
papasue wrote:Hi, I have looked for a tut on registration marks to no avail, but I have an alternative for u,
https://www.youtube.com/watch?v=H8pkru4qVZgRachat prĂȘt
Hi, thanks for links
