Send from CorelDRAW to SCAL PRO
craftedge
Site Admin
Post by craftedge »
If you use CorelDraw, you can use the Sure Cuts A Lot Pro plugin to transfer your design directly from CorelDraw to Sure Cuts A Lot Pro.
Important: Please note this will not work with the Home & Student version of CorelDraw. You will also need to make sure you installed VBA (Visual Basic for Applications) when you installed CorelDraw.
You can download the plugin at http://www.craftedge.com/download/download_extras.php
Make sure you download the correct plugin for your version of Sure Cuts A Lot Pro and your version of CorelDraw.
After you download and run the installer for the plugin, you should now be able to see an option to Send to SCAL from the Application Launcher in CorelDraw.
If CorelDraw was running when you installed the plugin, you will need to restart CorelDraw before the Send to SCAL option will appear in CorelDraw.
After choosing Send to SCALPro in CorelDraw, it should transfer your design to the workspace in Sure Cuts A Lot Pro.
