Thinner lines
Thinner lines
Is there any way to make the lines thinner when tracing something in Inkscape? When I trace stamps, the lines sometimes turn out too thick even when I dial down the threshold numbers.
Re: Thinner lines
You can use Path/Inset or Dynamic Offset to make the lines thinner. Dynamic offset will give you more control, then use Path/Union or Object to Path when you are done. HTH
Re: Thinner lines
Thanks, Heather, I think I asked this once before and forgot the answer!
