Print & Cut - Scal3 is running very slow
Posted: Fri May 24, 2013 4:52 pm
Hi there,
I realize this is a lot at once.... But my first hurdle is that SCAL is running obnoxiously slow....
If it matters...I am running Mac OSX 10.8.2, Adobe Illustrator CS3, Printing on a Canon Pixma Pro 9000 MarkII, Cutting with a Silver Bullet 24".
What I'm doing:
-Designing tags for favors in Ai, so there are about 50 tags to a 12x18" sheet.
-saving as SVG (file is 549KB),
-Importing SVG into Scal3,
-Duplicating the image to fill my paper space making the file 174 MB.
I feel the file size is making the program move slow, is there something I can do like flattening to decrease the file size without loosing vector quality?
Even the preview option, where you see where the cut is going to be, takes a long time.
I try to Print and Cut, and I get the spinning beach ball, I end up force quitting Scal after an hour of nothing.
I tried to just Print, a basic print window with the option for registration marks pops up, not the Print and Cut window where you see the virtual mat.
I choose to print with registration marks, it tells me the images are in the way, but it seems like no matter how much room i give it, it still tells me there isn't any room for registration marks.
So I choose to print anyway, and again the spinning beach ball of doom, and it times out after an hour of no printing.
I started a new file, with only 6 of the tags instead of 50. SCAL still moves slow, but after about 5 min it prints with the correct registration marks, but my design is only a solid fill... I had this problem before, and fixed it but can't remember what I did to fix it?
I've tried to install the SCAL AI Plugin, but I keep getting this error message:
Can't make "Macintosh HD:Applications:Adobe Illustrator CS3:Presets.localize:Scripts:"into type number
Do I really need this Plugin? I can save my AI files as SVGs manually. Is there any other benefit to this plugin?
Do I HAVE to run Scal for the Silver Bullet? Is Ecal or directly from AI an option?
I have printed before from Scal, but I have yet to print AND cut with any success. The mat continues to spit out at me...but that is a whole other topic, but if you have any suggestions that haven't been posted before I'll gladly take any help I can get!
*Other notes*
I would like to set up images in AI...but it wouldn't load at all, I had to copy and paste all the tags in Scal... this process it too long when there are this many thing to set up.
I also outlined my type in AI, does this affect the file size?
Also all of the design elements are on one layer.
Like I said, I know this is A LOT at once, but if anyone can help I would be forever grateful!
What I'm doing:
*Other notes*
