Printing without using a mat
Posted: Mon Apr 15, 2013 10:34 am
by tinroofsunday
Hey all,
I'm a new Cameo user and while I've had a blast with it so far, I've run into a snag with SCAL3 that I haven't found searching the forums.
I know with the Silhouette Software you can print without a mat, which enables you to print items longer than 2 feet but I'm not seeing a spot in SCAL3 to set this up. Any insight would be appreciated.
Re: Printing without using a mat
Posted: Mon Apr 15, 2013 11:34 am
by dragonlord666
use the custom mat size and put that to what you need.
Gaz
Posted: Mon Apr 15, 2013 12:42 pm
by tinroofsunday
Thanks. Do I need to change the pressure or anything?
Posted: Mon Apr 15, 2013 3:36 pm
by dragonlord666
pressure will depend on what media you are cutting.
vinyl will use a lot less pressure then say, 200gsm card, for example
Gaz
Posted: Mon Apr 15, 2013 4:01 pm
by tinroofsunday
OK so my understanding is that I use the proper presets for what ever media I am using, input the size of my document and proceed like normal but with no mat.
Thanks a bunch. I was unsure if the absence of the mat would necessitate the need for changes in the cutting settings. I will give it a try. I appreciate your time
Posted: Tue Apr 16, 2013 7:54 am
by dragonlord666
In theory, yes, BUT (ain't there always a but? LOL)
what are you cutting without a mat?
vinyl is normally OK as it has its own "mat" in the form it's backing
the mat is there to stop what you cut from falling into the machine and getting in the way of the blade.
if my media did not have a backing I would not try cutting it without a mat unless I altered/designed the file with "tabs" to hold it together until I was ready to pop it out
Gaz
Posted: Tue Apr 16, 2013 9:21 am
by tinroofsunday
I am cutting vinyl so hopefully I should be ok. Thanks again for taking the time to clarify.
Posted: Tue Apr 16, 2013 9:33 am
by dragonlord666
that should be OK.
i don't cut a lot of vinyl.
keep an eye on the vinyl and watch for it drifting off to one side.
you can minimise this by pulling the vinyl off the roll and letting it pile up so there is little to no "pull" on the vinyl.
Gaz
