measureing
Posted: Fri Oct 12, 2012 8:57 am
by belindapooley
How do you measure exact measurements on the virtual mat? Example I want to cut a rectangle exactly 3.5 x 4.5 and when I measure it on the mat, when I cut it it is smaller than I set up.
Thank, Belindapooley
Re: measureing
Posted: Fri Oct 12, 2012 12:59 pm
Hi, I don't measure on the virtual mat, I use the properties box and enter the exact size if want.
I use the virtual mat rulers only for placing colored papers to cut out multiple objects.
Here's a pic of the area for size in the properties pane. If this is not what you meant try and agin to explain since I often misinterpret questions.
- size image.png (35.04 KiB) Viewed 2138 times
Re: measureing
Posted: Fri Oct 12, 2012 1:09 pm
by mommyshome
That's just what I was going to suggest, it should be exactly right then.
Re: measureing
Posted: Sat Oct 13, 2012 10:49 am
by belindapooley
Thank You very much. I saw that in the tutorial. I did'nt know that would give me the size I need. I will try it...Thanks
