Maybe I need to be clearer!
Posted: Tue Mar 04, 2008 6:41 pm
by Adrian
I really need help on this and I was thinking that maybe no one responded to my first post because I wasn't clear. All I want to do is copy and paste the in Inkscape. When I do this, the object is not the same size as the first one. What am I doing wrong?
Sorry, I'm doing a real lousy job of being clear!!!! It's SCAL that I need to duplicate.
Re: Maybe I need to be clearer!
Posted: Tue Mar 04, 2008 6:53 pm
by jancy
in inkscape, try edit: duplicate. this will dupicate the image. it will be right on top of your image/file, so you'll need to select it & move it.
Posted: Wed Mar 05, 2008 1:22 am
by susibi
OK - I hope this solution could be of help:
Imported Inskcape files come up very small in SCAL and have to be resized. I work in Metric so resizing in inches is a double pain but I'm sure we'll be getting metric soon!
It is possible to move one file over the other in SCAL and resize but it's hit and miss and makes your program crash.
I have no problem with copy and paste in SCAL my files come up the same size - if that was what you were asking!
What I can suggest is : In Inkscape make your welded word then click on it and note the measurements that appear in the top tool bar; then make the mat for the word and note down the measurements.
Import your files eparately to SCAL then resize to the measurements you had in Inkscape by inserting those values in the properties box.
For a simple shape this should be OK.
For paper piecing you will have to do this to every piece - a bit long winded but at least you'll know your cut outs will be proportionate.
In my tut for the mat card I did manage to put the cut out word over the card and resize it but SCAL crashed about 5 times in the process.
There are a lot of problems with this program as IMO it was designed primarily for using the fonts and dingbats -ie. type and cut. What we are basically now requiring the program to do is act as a full blown graphics program with ability to select using click and drag, layer, draw, weld etc which is a huge step up from what it was intended for.
HTH
Susibi :D
PS I think poor Todd has his work cut out for the next year or so!
