Installing Inkscape
Installing Inkscape
So I finally decided I want to try Inkscape after YEARS of agonizing and investigating...and being jealous of others' capabilities. And now...I can't even install it. I'm on a Mac, OSX, version 10.5.8. EVERY time I try...it crashes. Maybe I'm doing something wrong. I feel like a real dummy...and it makes me wonder if I should just forget using inkscape. Oy!
Re: Installing Inkscape
are you installing the correct version for your os
Hey there, I appreciate your help! I'm installing version .48.1-1-Leopard+dmg...I *think* that's the right one??? So complicated!!
yes I am pretty sure it is..Lauram312000 wrote:Hey there, I appreciate your help! I'm installing version .48.1-1-Leopard+dmg...I *think* that's the right one??? So complicated!!
Sometimes when the install goes wrong it leaves bits in the system, if you have an uninstaller program such as the free Appcleaner http://lifehacker.com/5828738/the-best- ... er-for-mac it may be worth uninstalling with that, restart the computer and download the program again.
I cannot help much more as I have never used a mac in my life, but that is the advice usually given on blackcatforumuk with install problems.
This may be of help, you may understand more of it than me..
http://wiki.inkscape.org/wiki/index.php ... g_on_a_Mac
For what it is worth..
If you get it working Inkscape does have quite a steep learning curve, but once it starts to fall into place it is without a doubt the most amazing software.
I use inkscape 99% of the time and it is absolutely brilliant, quite unbelievable that such a great editor is actually completely free!
Hi, somewhere in the fine print you will see that you need a FREE program called X-11 installed on your Mac for Inkscape to run.Lauram312000 wrote:Hey there, I appreciate your help! I'm installing version .48.1-1-Leopard+dmg...I *think* that's the right one??? So complicated!!
Here's one link I found where you can download it. Google x-11 Inkscape for more info.
http://wiki.inkscape.org/wiki/index.php ... 810.5.x.29
Hope to see you up and running soon,!
Thanks y'all have been so helpful...I've tried several times...and I'll uninstall and start again.
Wish me luck!!!
Wish me luck!!!
