Help with a SVG...Simple strawberry SVG
Posted: Sat Sep 11, 2010 7:34 am
by kkramsburg
Hi! Need a quick, simple help, I think....I'm looking for a free Strawberry svg. I need to cut about 90, so my college daughter can use for nametags at a Kappa function. I found one I love, up above, from The Wolf Lady, however, it has 'seed' cuts in the strawberry. I'd like a blank strawberry if possible. It will be better for writing the name....any suggestions or how to's on how to take the 'seed cuts' out?
Thanks!
Kim
Re: Help with a SVG...Simple strawberry SVG
Posted: Sat Sep 11, 2010 7:37 am
by GrammyKrausse
edit
Posted: Sat Sep 11, 2010 7:44 am
by GrammyKrausse
kkramsburg wrote:Hi! Need a quick, simple help, I think....I'm looking for a free Strawberry svg. I need to cut about 90, so my college daughter can use for nametags at a Kappa function. I found one I love, up above, from The Wolf Lady, however, it has 'seed' cuts in the strawberry. I'd like a blank strawberry if possible. It will be better for writing the name....any suggestions or how to's on how to take the 'seed cuts' out?
Thanks!
Kim
I know in Inkscape if you use your nodes tool and highlite the seeds then choose the delete function it will get rid of them.
Or you should be able to open the svg in Inkscape and break apart and move the larger red part of the strawberry away from the seeds and then draw a box around the seeds then deleete. I think this will get you a unseeded strawberry. Hope this helps
Posted: Sat Sep 11, 2010 11:16 am
by pastda3
This link has a file by ladywolf and it's already separated.
http://forums.surecutsalot.com/search.p ... mit=Search
Posted: Sat Sep 11, 2010 6:25 pm
by DaiseyDrmr
You can find a cute strawberry here.
http://svgcuts.com/blog/2009/05/26/free ... trawberry/ It comes with three files. If you don't want seeds, only cut "strawberry top" and "strawberry bottom."
