USB Driver install error **Solved**
Posted: Wed Jul 14, 2010 5:20 pm
by Applefamily
A note pad document was outputted to my desktop here is its contents:
Install USB Driver
App: dpinst64.exe
Cmd: dpinst64.exe
Err: 183
Dir: C:\Program Files (x86)\Craft Edge\Sure Cuts A Lot 2\CDM 2.06.00 WHQL Certified
My system is:
Windows 7 Pro 64 bit
Re: USB Driver install error
Posted: Thu Jul 15, 2010 12:31 pm
by nicolegregg
Did you ever get a solution to this error? I am having the same issue now...BOOO! Thanks
Posted: Fri Jul 16, 2010 9:19 am
by Applefamily
nicolegregg wrote:Did you ever get a solution to this error? I am having the same issue now...BOOO! Thanks
No and I have not spent much time trying yet either. I have it working on my other PC for now if needed. Looks Like I will need to contact Craft Edge soon.
Posted: Fri Jul 16, 2010 5:33 pm
by Applefamily
I have the solution from Craft Edge
Right click the application and choose Run as Administrator
Then Install USB Driver
Confirmed It worked!
Posted: Sun Jul 18, 2010 7:04 am
by nicolegregg
Applefamily wrote:nicolegregg wrote:Did you ever get a solution to this error? I am having the same issue now...BOOO! Thanks
Yeah I have done that and I keep getting the same response, update driver...it won't find it so that I can update it...sooo frustrating! I cannot find a phone number to contact them only email....there has to be a phone number so that I can speak with a live person...I hope anyways.
If I get a solution I will let you know...I will not give up!
Nicole
Posted: Sun Jul 18, 2010 10:47 am
by Applefamily
nicolegregg wrote:Applefamily wrote:nicolegregg wrote:Did you ever get a solution to this error? I am having the same issue now...BOOO! Thanks
Nicole
See Above..
Re: USB Driver install error **Solved**
Posted: Tue Jul 20, 2010 5:36 pm
by hope9811
This is a cricut issue....cricut has not updated their drivers to be compatible with windows 7 yet. It seems to only be an issue with those using windows 7 on a 64 bit computer. Here is a link that will fix the problem for you. It worked on two of my friends computers with this same issue. Good luck!
http://www.cricut.com/messageboard/tm.aspx?m=6784383
Heidi
Posted: Fri Aug 13, 2010 11:06 am
by ashleeboren
you are amazing! I love you! I have just spent the last hour trying to find help! Thank you thank you thank you- i was startingto regret buying this program but you saved me and made my year! thank you ashlee
Posted: Wed Nov 17, 2010 10:54 am
by susiecm3
thank you for this, was having driver error now all sorted
