virtual mat & actual mat-cutting
Posted: Mon May 24, 2010 4:56 pm
by louismom
I need a tutorial! Ok- you've got an image in the upper left corner on the screen & then it cuts in the upper right corner (but it rotates it)- got that. But it doesn't keep moving clockwise??? I've hit "cancel" so many times while cutting- Is there a diagram somewhere that shows where an image will cut?
Re: virtual mat & actual mat-cutting
Posted: Mon May 24, 2010 5:48 pm
by judyjo
Look at the arrows on your virtual mat, then on your actual mat. Line everything up in same corresponding way and it should cut correctly. Hope I explained it in an "understandable" way.
Posted: Mon May 24, 2010 6:29 pm
by louismom
Duh!!! I've been looking at this the wrong way- never even looked at bottom of virtual mat & wasn't paying any attention to arrow on left of screen. Now it all makes sense. Thanks for taking the time to answer such a silly question.
Posted: Tue May 25, 2010 3:41 am
by kelsie94
Never think your questions are silly! This forum is all about learning so ask away! There's always someone around here to help out.
Posted: Tue May 25, 2010 4:21 am
by judyjo
No no no, not a silly question at all. Glad you were able to figure it out
Posted: Wed May 26, 2010 4:54 am
by SeeJaysPlace
you can also move the arrow on your virtual mat to point up
under the document put it on Vertical (Portrait)
it helps for me alot
