I am an Inkscape idiot!
jeanaecroxton
Post by jeanaecroxton »
Okay, so once I import an image into inkscape, then what?
AnointedHands
Re: I am an Inkscape idiot!
Post by AnointedHands »
You will have to trace the file in order to import it into SCAL.
Check out the tutorials in the Inkscape>Tutorials section
Link below
http://forums.surecutsalot.com/viewforum.php?f=17
kkrewtea
Post by kkrewtea »
HEY! That's my title! I'll let you use it for now though. Before you know it, you'll be a master! GOOD LUCK!
Shirl
Mikey
Post by Mikey »
I just tried it out today, and had to go onto the Inkscape help to figure it out..
Open your file in inkscape
Select the image
Click on Path, Trace Bitmap
Click on OK on the window that opens
It won't look like anything happened to your image (it didn't on mine) but I saved it as an SVG file and imported it into SCAL and it worked!
Good luck!
kkrewtea
Post by kkrewtea »
If you want to SEE what will cut in inkscape just go to view>outline....Then you will be able to see the cut lines...
Shirl
