Question from New User
gwcrow
Post by gwcrow »
Is there a circle shape that has an inner and outer circle like the letter o. I hope I am asking this question so you understand. Thank you so much
firstcut
Re: Question from New User
Post by firstcut »
No, but you can use the circle from basic shapes, make 2 of them in the sizes you want for inner and outer, select them both and then use the alignment buttons to make them concentric. Then group them so you can move them where you want them.
gwcrow
Post by gwcrow »
I tried that but the problem I am having is when I over lap the ovals into say in a number 8 configuration and weld the inner circle is not visible. If I do the same thing to two O's they are only welded where they overlap. I may be missing something so parden my ignorance.
Shelley
Post by Shelley »
try
-->path
-->union
you have to drag a square around it first... from way off your image, click and drag then path, union... try that?
from The Wizard of Oz
gwcrow
Post by gwcrow »
Yes that worked with path and union. I appreciate your help very much. Thankd you
