Page 1 of 2
Inkscape Word Book for SCAL
Posted: Fri Mar 19, 2010 4:41 pm
by doodlebugs
I am so new to this not only to SCAl but to Inkscape as well. I found an awsome TUTORIAL on how to do this but when I try two sepate things it still does not work.
The first thing I am trying is that in the video when joining the rectangle to the letter after you align the box with the letter, tou are supposed to go to path Union. In the Tutorial, when this is done the letter turns to be the same clar color as the box and you can tell it is welded togther. When I try it it does not change now sometimes when they are both selected it looks like they are united but if you click and move the letter, it is not. What the heck am I doing wrong?
The next issue is in the Tutorial he shows how to make the center of the letter D as one so that the hole does not cause issues. When I try it with the letter A Nothing happens I am going crazy/ Thanks in advance for the help
BTW I hope this is posted in the right place I was not sure I was alowed to share the place where I say this so I will if needed
Re: Inkscape Word Book for SCAL
Posted: Fri Mar 19, 2010 6:28 pm
by Sweetness4713
If you are doing this right in inkscape set the viewing image to outline mode .. Make sure you letter and the rectangle are overlapping a bit and then go path/union... I find using the outline mode the easiest when joining stuff...
Posted: Fri Mar 19, 2010 6:39 pm
by doodlebugs
Sweetness4713 wrote:If you are doing this right in inkscape set the viewing image to outline mode .. Make sure you letter and the rectangle are overlapping a bit and then go path/union... I find using the outline mode the easiest when joining stuff...
Oh I appreciate your help its still not working also the part where you break apart the letter then go to difference it is not selecting the center of the letter. This is the gentlemans tutorial I was using I hope it was okay to share I think it is great if not please let me know and I will delete
http://s71.photobucket.com/player.swf?f ... &os=1&ap=1
Posted: Fri Mar 19, 2010 6:45 pm
by Sweetness4713
To select the center hold you shift key down and click on the center and then click on the out part of the D.. if path/difference doesn't work I normally would go path/combine...
Posted: Fri Mar 19, 2010 6:47 pm
It's not working because he is using Inkscape 0.46 or older and you are probably using Inkscape 0.47. Ink47 puts text into a Group when you use Path/Object to path and you can't use most of the Path operations on a Group. You actually don't need to convert it to Path if you are typing one letter at a time. You also don't need to break apart the letters and then use Path/Difference with Ink46 or Ink47.
If you are typing the letters one at a time, just size and position them, then select the letter and the rectangle and use Path/Union.
If you are typing all of the letters at once with Ink47, select the letters, Path/Object to path, right click on the text and select Ungroup. Each letter should then be a Path by itself. Just position it where you want it, select both the letter and the rectangle, and Path/Union.
Posted: Fri Mar 19, 2010 6:51 pm
by Sweetness4713
Heather you are so much better than I am at trying to describe what to do..LOL..
Never even thought to ask if she was using Inkscape .47 which is what i have..
Also with the new SCAL2 you shouldn't even have to do this in inkscape as it can be done right in SCAL2..
Posted: Fri Mar 19, 2010 6:55 pm
by doodlebugs
THANK YOU THANK YOU I may be able to do it now You are a life saver :D
Posted: Sat Mar 20, 2010 5:41 pm
by doodlebugs
Okay more issues, thanks to HeatherbI was finally able to complete my first wordbook well sort of...Now that all the letters are set I copied each and saved it in inkscape to a page for each letter. When I go to SCAL and import SVG all the letters open except one the A in Dance does not come through what could I be doing wrong?
Posted: Sat Mar 20, 2010 5:53 pm
by Sweetness4713
Did you click path/union??? in inkscape...
Posted: Sat Mar 20, 2010 7:14 pm
by doodlebugs
Yes but I tried to recreate it all over again and only a coulple letters are coming into SCAL also the D is missing the hole :(
