Sure Cuts A Lot 2.011 Update Released
Locked
craftedge
Site Admin
Post by craftedge »
New version (2.011) for Windows and Mac is available for download now on our site
http://www.craftedge.com/download
To update from a previous version 2, just download and install over the current one.
Make sure the program is not already open and running when installing the update.
* Added Text on Path tool under Type Tool
* Added Line Style option in the Appearance properties
* Added option to change the shapes color in the Appearance properties
* Added Text menu to change fonts from the menu bar
* Style menu changed in the Appearance properties
* Added USB Driver install option under the Help menu (Windows only)
* You can import scut2 or SVG files by choose Import from the File Menu
* Added Personal Library under the Window menu so you can store your SVG, SCUT files in a single folder. Folder location can be changed in the Preferences (Windows only right now)
* Preferences has option to choose a folder where you should store your lcut2 library files. You should not store your own lcut2 files in the Sure Cuts A Lot 2 application folder anymore
* Various bug fixes
balletcostumemom
Re: Sure Cuts A Lot 2.011 Update Released
Post by balletcostumemom »
Thank you for the update. The only thing I'm not seeing is the Text on Path tool under the text tool.
talanhart
Post by talanhart »
I wonder what bugs were fixed?
Ohhh I love that the text option is on top now on the tool bar.. yippeeee.. Love the changes. :D
talanhart wrote:I wonder what bugs were fixed?
Yes they say fixed but don't say which ones were.. hmmm
balletcostumemom wrote:Thank you for the update. The only thing I'm not seeing is the Text on Path tool under the text tool.
It's in the drop down part under Vertical type.
It looks like they have fixed the Ink47/SCAL2 compatibility issue, but I only tried a quick test so I might be wrong.
Macintosh checking in. Yipee! so far so good. It opens Ink 0.47 just fine, breaks apart, I was even able to delete some "nodes" that crept into my files.
LOVE IT.....
Didn't have bugs before but i sure do now with the update :( .. The mat is showing cutting complete and it hasn't started.. I'm reverting back to the previous upgrade until this problem is solved.. grrr..
Judy*
Post by Judy* »
Sounds like a few people are having problems with the update. Don't think I'm going to be updating anytime soon. :|
TOASTER
Post by TOASTER »
I'm going to wait to update too just in case... but I'm wondering... will I understand the features of the new update?
Toaster
SCAL 2 , SCAL 3, Windows 10
Locked
