Poinsettia Frame
Re: Poinsettia Frame
whoohooo.. awesome Todd.. Aside from that little box in the middle..LOL. but then I realized if I ungroup in scal.. I can get rid of it.. So now I'm going to have fun with it and create something and I'll bring it back in to show :D
danie
Post by danie »
Somebody can make this frame??? I try it an it cut not good. I found it is so beautiful and I want tou make it on the christmas card. Somebody cant help me. Thanks
GrammyKrausse
Post by GrammyKrausse »
Danie
can you tell us a little more on the cutting or not being able to cut. More info is needed to figure out what went wrong.
Grammy
danie
Post by danie »
I beginning with black frame and it cut many time on the poisettia. I try the seperate files with three layers. I am not sure I am clear in my explication. My english is poor. Thanks
talanhart
Post by talanhart »
Danie,
6 posts up, you will find the same file separated into the three colors. You have to download all three files.
danie
Post by danie »
It is this one who I try and when I cut the layer black the cut don't make the blackout it beging to cut the flower in small piece.
GrammyKrausse
Hello again Danie
If you are using SCAL 1. the black one is grouped. Scal 1. doesn't like groups.
You need to open them in Inkscape To get it apart. choose the Object icon then ungroup once to make it two groups then then choose the poinsettias again to ungroup them and after you get them ungrouped you need to path break apart the poinsettias to get the backgroud away from the petals. Same with the black back ground it is also needs to do the path break apart. If you keep an eye on the center bottom of page in Inkscape and it will tell you when they are no longer grouped.
After you get them ungrouped and broken apart you can place them on the mat the way you want
If you are using SCAL 2. it will accept groups and you need to get the poinsettias and do a path break apart in Inkscape to be able to get the layers that you can move where you want them.
Hope this helps
Grammy
danie
Post by danie »
I have the scale 2 but I don't no what you said with ¨you need to get the poinsettias and do a path break apart in Inkscape to be able to get the layers that you can move where you want them. ¨
GrammyKrausse
Yes Danie
Do a object ungroup first and it will give you two groups, one of the frame and one of two poinsettias. then with your curser choose the poinsettias and do another object ungroup, this will give you two poinsettias. Choose one of the poinsettias and do another object ungroup and do a path break apart. That last step will cause the layers, and then of course you have to do the second poinsettia with follow the ungroup and break apart options. One thing to remember these are all grouped and then regrouped in sections. If you are using SCAL 2. you are only concerned with the poisettias so you can eventually break them apart.
Grammy
Darn!!! I made the card but forgot to take a picture of it.. It turned out beautifully .. I used it as a window on a card.. I already gave the card out in a gift exchange :( The only part I had a hard time with was the outlines of the pointsettias so I outlined with a black marker..
