Taking Requests - Any SVG Shape
Locked
DogCarbon
Re: Taking Requests - Any SVG Shape
Post by DogCarbon »
and here is the bulldog.
this file is color grouped.
the base is white, then the gray layer, then the black outline, and finish with the blue collar.
Also,
You could cut the black outline as a window decal.
Hope this works for you.
bulldog.svg
(58.11 KiB) Downloaded 587 times
nanacho
Post by nanacho »
Hi...would it be possible to make an svg for this cupcake wrapper?
Thank you so much for your generosity in sharing your talent and time...it is very much appreciated!
cupcake wrapper Filigree_CWR_White.jpg (209.75 KiB) Viewed 7744 times
Bani
Post by Bani »
jcleith wrote:ok i cut the file and it cut some things i dunno if im doing it wrong or it just doesnt look right what you think?
I think you got most part right with two exceptions.
The cut you had on white paper should be the brown cut. And the cut that is on the brown paper should be on white.
Secondally, you may need to adjust the size of the green jacket to fit the size. I eyeballed it when I placed it on the SCAL. So you may have to adjust the size of the jacket to nicely fit. It seems like that the boy is wearing XL size while a Medium size jacket should do ;-)
Bani.
Bani
Post by Bani »
nanacho wrote:Hi...would it be possible to make an svg for this cupcake wrapper?
From the image you provided, this is the closest we can get. Your best bet will be to start from a pattern image instead of the picture of end project. But give this a shot.
Bani
CupCake-PATTERN.svg
(73.37 KiB) Downloaded 687 times
nanacho
Post by nanacho »
wow...thank you so much, Bani!!!
I think the best thing to do in this instance would be to buy the wrapper, and then make your own by opening up the cupcake wrapper so it lies flat and scan it and then create your own....
nateandsara
Post by nateandsara »
I am in DESPERATE need of this image as an CUTTABLE COLOR BROKE APART SVG CAN YOU HELP??
i ONLY NEED THE INDIAN AND THE WORDS, NOT THE DARKER PART
gerald
Post by gerald »
thank thanks thanks. you are great.
nateandsara the image is too small.. we would need a bigger and clearer image to convert it over to an svg..
gmapatty
Post by gmapatty »
Hopefully you are still requests. I was wondering if you could anything with this file. I have tried to put it together in SCAl with no luck.Thank you for your help.
I am hoping that someone can help me, please
softball_girl.scut
(26.04 KiB) Downloaded 569 times
Locked
