SCAL Built In SVG Preview Feature - Personal Library
balletcostumemom
Re: SCAL Built In SVG Preview Feature - Personal Library
Post by balletcostumemom »
Thanks leo. I did categorize them, took a good bit of time doing it yesterday. But didn't try Personal library until after I categorized and I do have Scal 2.103. I can't get past the point where it should be taking the time to fill with the categories. Any other suggestions?
leokowal
Post by leokowal »
Make sure that under Edit >> Preferences, the User Artwork folder shows the correct location, if not, you may have to specify it again. Also just tried changing the name of the file thinking that might help, but still got the error message.
Leo
SVGCuts.com
balletcostumemom
Yes, under edit the preferences points to the correct folder where the files are stored for both the scut and svg files.
balletcostumemom
Ok, I think I solved it on my own. But I'm not sure which of the things I did today solved it. It was either that I had some scut files in with some svg files in a few folders. OR it was that I had some zip files in one of the folders that had not been unzipped yet. Not sure which because I did both before it worked. But it did work today.
