I'm guessing you designed the tag with a rectangle and just put them next to each other on the mat which is why it is cutting twice. The computer reads the inside lines as two lines along the rectangle. To fix it, I created a scut file with a small space between each tag which will then cut only one time along the outside lines. My file only has one row of tags. Just do a cut and paste to add more rows of tags.evamar wrote:Hi there, many thanks for your help, I thought that I couldn't select both things... silly me!![]()
Just one more question... is there a way for the cricut to cut only once where the tags meet? The blade still passes twice even though in the virtual mat I can see only one line.
How can I put 1 shape inside another in SCAL?
Re: How can I put 1 shape inside another in SCAL?
- a4 choc hearts card scalloped2.scut2
- One row of tags
- (75.94 KiB) Downloaded 150 times
- Photo of new file
- Heart tags.JPG (54.82 KiB) Viewed 2959 times
Hopefully this will work for you.. before you group your work just do the one tag then select the heart and tag together and then go path/exclusion.. then duplicate your tag afterwards... I've fixed the file for you so hopefully this helps...
Whoops sorry Deloris.. I didn't realize you had fixed it for her..
If it's cutting it twice, do you have it set on multiple cut? That is another dandy feature used for thicker things like chip board, etc.
from The Wizard of Oz
I would love to see one finished. If you have a chance please show us. thanks.
SORRY! I have been so busy that I haven't visited for a white. I'm attaching a pic of the finished choc cards for you to see.mamajo wrote:I would love to see one finished. If you have a chance please show us. thanks.
Many thanks for helping me out, I really like how they came out. I just couldn't find a way of printing them before cutting as I couldn't make the correct measurements, so I'll simply write her name on the card with a pink sakura gel pen to match the chocs. I'm using a thin ribbon to attach them to the final favours, sorry I cannot make a pic of the final thing, they still haven't decided what to give!
Only thing is that it takes a while to cut the hearts as they are scalloped. I'll try to find a normal heart of the right size for the choc hearts in the future.
Kind regards,
Eva
- corazones-cristina.jpg (28.54 KiB) Viewed 2943 times
That is a beautiful idea as a favor alone. I would make the tags a little larger so I could put the name[s] along the bottom of the heart and the date along the top of the heart. You could print the names in SCAL using a gel pen and then cut.
Once again, the possibilities are endless.
Althea
Althea
Eva that is absolutely gorgeous.. They turned out great... Someone had a video on their blog.. I think it was Papasue and she showed how you write on your cards using your printer before you cut the image out or it was vice versa.. Anyone??LOL
Dang it!! I was having the same issues a few months ago! I got it to work now. Thanks for the info... But do you think I can remember what I needed it for now? NOOoooooo!!! LOL!
awesome, awesome, awesome. i mite make some as favors for a wedding shower. too cute
Theresa
