HELP!!!
JanetL
HELP!!!
Post by JanetL »
:?: :cry: I need some help.... I have attempted to use SCAL2 on both my netbook and my desktop. I have a file that Kathy a friend of mine made for me and I am attempting to switch the names around on the design everytime I click on the break apart and start to move things around the program shuts donw. I even went so far as to uninstall the program from both machines and redownload and it still keeps shutting down. I need to get this design done so that I can cut 40 pieces out of vinyl for my SIL wedding... Please help. I cannot figure out why the program keeps shutting down and stating that an error has happened.
Thanks to anyone for some help.
Re: HELP!!!
Did you try Object/Ungroup first? Also, what version of SCAL2 are you using?
If you can't get this to work, post the file and someone will try to help.
JanetL
Re: HELP!!!
Post by JanetL »
Ok I will try and see if that works.
JanetL
Re: HELP!!!
Post by JanetL »
forgot to answer your other question. Says my version is 2.029
JanetL
Re: HELP!!!
Post by JanetL »
well I tried it and even if I try object/ungroup it does the same thing.
Re: HELP!!!
What version of SCAL2 are you using? Also, is it a scut or svg file?
JanetL
Re: HELP!!!
Post by JanetL »
when you ask me what version I am looking at the login screen that tells me the version or is that not correct? I am rather new at this program. 2 weeks ago my SCAL2 was running fine but for the last week it just keeps closing no matter what I try to do.
JanetL
Re: HELP!!!
Post by JanetL »
it is an SCUT2 file
Re: HELP!!!
The start-up window or from the menu Help/About will tell you the version.
Your best option may be to upload the file so that someone else can try.
