Ever single SVG I download and open with SCAL doesn't show
tatiana8
Post by tatiana8 »
I just hit download for a really cute frog svg and it said open with scal so I did and nothing shows up...can someone please help me...thanking you in advance
jsnstarprncss
Re: Ever single SVG I download and open with SCAL doesn't show
Post by jsnstarprncss »
you have to reopen it in SCAL. Mine does the same thing and has with XP and Vista. It's not like opening a word docutment or anything just make sure you have SCAL open first, then click on the import folder for importing SVG's. It's better if you set Inkscape as your program of view choice because it makes things easier :) HTH :)
~Ashley
Psalm 113:3 Creations
mikiela1
Post by mikiela1 »
Rather than hitting open... Import the file into scal. Once you have Scal open under file, click import and find your file to import. It should open for you that way. Hope that helps
coocoo4cricut
Post by coocoo4cricut »
I hit download and it will open SCAL(no svg shows up) then I just close SCAL out, go to the download window,right click,click on "show containing folder" or something of the sort
go to that folder which in mine is temporary files,then I drag it to where i want to store it, then you can import svg into SCAL
sounds confusing but real easy
hope it helps
GrammyKrausse
Post by GrammyKrausse »
If it is a true svg you import in Scal. It shouldn't even try to open. If you have inscape try to open it and see what is there.
re:
and if it is a zip file you need to unzip it first then save then import in scal
