Rolland 60 degree Blades ?
Ok! I have just purchased some rolland 60 degree blades to cut some word books from chip Board, can someone tell me do I still need the deep cut housing?
Wendy
Wendy
Re: Rolland 60 degree Blades ?
I'm not an expert here but I think you just need to change the blade.
I just used the blue housing because I got deep cut blades set from Cricut.
Hope to get that Roland 60 asap
best,
paulo/brazil
best,
paulo/brazil
I just use the blade in the normal housing
Thankyou for your replies, I will now give it ago.
Cheers
Wendy
Cheers
Wendy
no worries wendy I use the blade for cutting stamps with my E
Is that the same as the deep cuts blade?
Thank you
Thank you
I believe so and if you buy them on ebay or at a sign makers costs you heaps less!
Hi
I have a few questions about these blades
So what are the benifits of these blades?
Will I still need to do multi cuts if cutting through cardboard?
Would there be any benifit using these blades all the time? I can get a set of 3 here in Aust on ebay for around $20 Aust. That's 3 for the price of 2 standard cricut ones.
Cheers
Craig
Update
I just found this and it confusses the issue in what blades to get
Cheers
Craig
Update
- show_angle.jpg (48.63 KiB) Viewed 3824 times
Cheers
Craig
Craig
well benefit is you can cut thicker material without the deep blade holder.
depends on your cardstock if you still need to do multi cut I guess,certainly cuts stamping rubber with one cut.
No need to use them all the time the normal blade has a different angle 45 degrees and cuts thinner papers better
Im in oz to but bought mine ex USA ebay got 6 even with postage was cheaper than 2 blades in oz.
Thank you so much for the info. The ad does confuse the issue a bit though doesn't it?
I will definitely try ebay.
