Plugins Problems
Plugins Problems
I cannot the get plugins for Corel Draw and Illustrator to work. The Corel Draw one shows up in the application launcher but just sits there when I try export to SCAL and the Illustrator one doesn't show up in the 'scripts' dropdown menu. I have Corel Draw X4 and Illustrator cs6. Has anyone else had the same problems?
Re: Plugins Problems
Hi, it would help if you posted what version of SCAL you are using, on what cutter and what Operating system your computer uses as it can make a difference. You can add this information to your signature so that it shows up with each post you make. With this information members with a similar setup will find a way to help you.
Windows 7 Professional, MH 14 inch cutter from US Cutter and the latest version of SCAL...
There seem to be a few bugs in SCALPro3.
There are "drivers" for corel on the support page. Did you get and install them?
http://www.craftedge.com/download/download_extras.html
Or you can contact CraftEdges support directly with all your questions.
You should contact CraftEdge Support directly with this.
http://www.craftedge.com/support/support_form.php
I hope you can get it fixed. I know how frustrating it is when something that should work doesn't.
